1 - 1 of 1 Posts
2003 C240
2002 C240- 90K miles
Hi all, new poster here. I just changed the oil for the second time on my wifes c240. As I was removing the plastic cover under the car, I noticed some grime and oil that was not there before. My first thought was that I did not tighten the drain plug enough last time... However, once I inspected everything, there was no oil leaking around the drain plug. Around the drain plug (and block) was clean. About 5 inches above the drain plug on the block and some tube going across laterally (no idea what it is) seem to be covered with oil.
I drained about 8 or so quarts from the engine so I do not think its that bad of a leak. Also, not spotting where it parks. Any thoughts help or suggestions appreciated.
Noob!
1 - 1 of 1 Posts
