1 - 14 of 14 Posts
1998 Mercedes-Benz S500
this is my 1998 W140 S500 n15/3 ecu. car in LHM(Limp Home Mode). can i just clean with som thinner and resolder or ........????????? Any Adias WELCOME. TNKS.
1997 E320, 1997 S320
you can give it a try. clean it with electronic parts cleaner, can buy it from radio shack to any autoparts stores. the connector plug that connects the etc (electronic tranny control module) to the transmission must have been leaking for a long time since the fluid reached the etc. hopefully after cleaning it will still work. sometimes you cannot reset the error codes just with obd2 scanner if they are tranny codes, you would need the mercedes diagnostics machine or carsoft if you have it in order to erase the tranny codes to get it out of limp mode. also make sure you put a new connector plug after you are done, they cost like $10.
by the way everyone with 722.6 tranny needs to check if that connector plug is leaking since it's pretty common. if the fluid leaks to far can reach the etc like in this case.
Moderator
SL55, 300SE, GL450, Daytona 955i
Do what???
what oil and how did it get there?
also, Limp home mode is not triggered by the tranny ECU.
1998 140.070 CL500, 1966 406.121 U65
Do what???
Bayhas, no offense, but I think you must read up on the working of the 722.6.
Maintenance Hints/Diagnostic Trouble Code Information
It can detect a lot of abnormalities in operation, and put the box into limp-home,
usually in 2nd gear forward and 2nd backward.
ATF oil can creep up the wiring with a leaky connector, by capillary actions, and
all the way up to the control module;
http://www.benzworld.org/forums/w210-e-class/1369000-transmission-fluid-leak-connector-2.html#post2811814
br,
syljua
Moderator
br,
syljua
I dont claim to be an expert on 722.6, but what made me make that comment is trannies trigger "protection mode" where the tranny doesnt shift to certain gears, or changes the shift point.
"limp home" mode, is in the ETA, and causes the gas pedal to be 50% lower (shorter... whatever you want to call it), and horse power output to be down to 2/3 by changing the timing.
BTW, protection mode is a feature in 722.5 as well, and if I am not mistaken, it kills the 5th gear.
1996 S500 coupe
mine has been weeping for a while now.. didn't realize it could potentially damage the board..
Called up the local dealer and he said he sells a lot of these and knew exactly where it was located and what the part number was .. lol
he said the plug comes with the o ring and it's packaged as a kit for $28
I will change it this weekend and post some DIY pics.
stay tuned
1996 S500 coupe
k, I have done a little digging around, and the part # shown in the first post is on top, inside the ecu box beside the blower fan... how does transmission oil get in there??
the part # on the others ide of the plug, from my understanding, is 1402701161 which is also known as an "electrics kit" shown here as per 210 FAQ section:
if that's the case, the whole assembly is inserted in trans. fluid, then how does a leak matter?
I guess I am confused because I am getting contradictory info about the location of this board
1998 S500
My understanding is that when the connector you reference is leaking, then ATF works it's way up the cable harness and gets to the module located in the coffin box.
FYI - While the connector is inexpensive, I tried to replace mine without the benefit of a lift by lying under the jacked up car. It was extremely difficult and I ended up having the dealer replace it. Can't recall how much I paid but it was very reasonable.
Well, in the first link I gave you, Mercedes call it Limp-Home-Mode for the
transmission also, so I'll stick to that.
br,
syljua
Discussion Starter #11
To All
thank you all for your support. keep it up!!!:thumbsup:
SEC 600 V12 2dr COUPE (RHD) One of the chosen few.
Physicaly its called Wicking..If you dont belive try it with a piece of string and some oil it takes time.. but it will creep up..
Moderator
1 - 14 of 14 Posts
