hi, i have a 1997 c250 w202. 262.000 miles on clock. i took off the top cover just cleaning stuff and nearly sh*t myself. the camshaft cover where all the injectors are had 2 of the wells filled up with oil. the 2 nearest the firewall.covering the injectors and leakoff pipes. anyone seen this before? any ideas where the oil is from?
2001 CLK55 AMG, 2002 C32 AMG
i believe there are spark plug seals to keep the oil out. i think, but am not sure, that to change these you will get a valve cover gasket kit and have to remove the valve cover to replace them. maybe someone who has done this before has more data on it.
thanks for your reply . was thinking seal or gaskets just wanted to hear if it was a common problem. anyone suffer this before?
mercedes c250
i know you replaced diesel leak off are ya sure its fully home ? i ll give ya a buzz soon
