98 ML320& 05 ML350SE
What if anything of consequence other than thinning out the viscosity happens when you add say 5/30W Mobil 1 to a ML that is filled with 20/50W Mobil 1??
If it is a 50/50 proportion, do you end up with a 10/40W equivelent weight oil??
'05 ML350SE
Topping off with a different grade is not considered
a problem. However, a 50-50 mix is a different story.
I suggest you put the question to Mobil.
