06 ml350
Hi,
Where is this located? Do I need to remove the engine cover? How do I remove the engine cover?
Thanks!
2002 honda civic (sold), 2009 Mercedes ML350
is located on the front driver side of engine. open the hood and remove the front engine cover and its right there.
06 ml350
Got it
Broke 1 of the clips in the process. How do you know where the clips are located. I kinda had to mucle it a bit. Broke 1 clip. It's all good. It's not going anywhere. It's on the with 3 clips and 2 snap round plugs. But damn!!! How were you supposed to know!!!
I got 5 quarts out! That tube was bottomed out. I used the Mightyvac. i thought i was supposed to get close to 8 or 9 quarts. I notice the oil is still a bit dark.
Thanks!
I pull the covers off everyday so for me knowing where the clips are and how they come off is easy. but I even break the clips, no big deal.
anyway i dont trust using a vac to suck out the fluid, at the dealer we all drain the fluid from the bottom. as said before a vac doesnt get all the fluid out.
