OIL drain plug
1169 Views 2 Replies 2 Participants Last post by  mynewbaby
please tell me what panel i have to take down to get to the drain plug. I need the procedure. If anyone can help me that would be great! Does the oil filter cover twist off like an oil filter??? I have a 1994 s320....thank you
S320W
The Oil pan has a screw. If you look at the pan from beneath, its on your right side. If you unscrew that screw, it will drain the oil from the pan. Be careful, keep your face away from the screw as oil will start dripping.
The filter needs a tool. You can find it any place that sells tools.
