1 - 20 of 38 Posts
1985 Unimog U1300L (diesel)
Hello There,
New owner to a Unimog U1300L (non turbo, chassis # Starts with 435115 10 xxxxxx, OM353 engine I believe) and I am hoping someone can answer a couple of questions regarding the engine oil dipstick.
1) Top portion of Dipstick, This rivet job looks like a repair to me, my operating instruction manual does not have a complete image so I just don't know?
2) Bottom of dipstick has no markings at all, after the twist there is an indentation which I could assume is where my oil should be?
my overall concern is that I maintain a correct oil level but this dipstick kind of leaves me wanting. Would appreciate some feedback from people in the know.
P.S. the two rivets make this horrible pivot point that makes it a pain in the ass to re-seat the dipstick and makes me wonder if the end even sits in a correct position to get an accurate reading.
2664727
2664728
U1450L DOKA
OK, a photo would be easier, but I can’t get it done .
So, I will try to explain what the data book shows on pages 294-295.
1. Your dipstick, from what I can see, is a Type A. If it has a clamp on top that locks the spring in the tube, as it seems, then this dipstick is for a 616 diesel, not a 352 (353.xxx).
The distance for this dipstick from the tip to the top of the round cap that seats on the tube is 657mm..
If your dipstick has this measurement, it is not correct for your engine. Even if it doesn’t, the book says that is the wrong one.
2. The correct type for your engine is either
a type C, or a Type D. Your serial number dictates the type, as well as the length of the dipstick, and the measurements of where the High and low marks are, etc.
There are 5 different sets of specifications for the dipstick for the non-turbo engine,
And another 5 for the turbo .
Here are the engine number choices.
If you pick yours out of the list and tell me the number , I can give you the specs for the correct dipstick. Then at least you can compare it to the one you have, and maybe make a punch mark or a notch with a file to cover you until you get the correct dipstick.
The engine numbers for the non/turbo:
353.902
353.970
353.940. (All type C)
___
353.949 (Type D)
___
353.961
353.962. (Type D)
__
353.985. (Type D)
___
353.999. (Type C)
Now, it isn’t as simple as you have a type D,
So here is the measurement. Each dipstick between the horizontal lines above has different dimensions than any of the others.
So, if you have an engine number , I will tell you the dimensions.
U1450L DOKA
Also, the type A, as you’d looks to be, does have a two rivet set up where yours is, but it is not the same.
Yours looks like 3 pieces: the top shaft / handle, the ‘link’ with the two rivets, and the bottom shaft to the top.
The original is just two pieces of shaft, with no ‘link’. The top shaft overlaps the bottom shaft, and they are riveted together into a solid dipstick.
Yours was probably broken and patched back together.
U1450L DOKA
It Could be that somebody tried to make a correct dipstick out of an incorrect one.
Once The engine number is determined,
You’ll have the dimensions and will be able to tell if your dipstick is in the ballpark, or off of the map.
Discussion Starter · #7 ·
353.902
353.970
___
353.949 (Type D)
___
353.961
353.962. (Type D)
__
353.985. (Type D)
___
353.999. (Type C)
2664730
Here is an image of the top of the dipstick which looks like the clamping variant you mentioned.
Regarding the engine identification 352/353 Where on the engine could I find some identification marks to make a definitive identification. Some research tells me I should find a number on the left hand side of the block but it is a tight fit and dirty and not 100% sure where to land mark to find it.
U1450L DOKA
The engine number is ‘usually’ stamped onto an aluminum tag that is on the passenger side of the block, Sorta low, to the rear of the injection pump.
U1450L DOKA
Yes, that is a Type A dipstick.
The aluminum tag is there on the right side of the block, as viewed from the driver’s seat
If you are lucky. ( same side as the dipstick tube)
U1450L DOKA
Photos working again.
Shown - Types C& D, and the dimensions on the table, relating to the engine number.
Baggage Paint Painting Still life photography Still life
U1450L DOKA
Text White Line Font Black
Type A for reference- the dimensions for this one are at the top of the first data page -
616 engine.
Discussion Starter · #15 ·
View attachment 2664739 Type A for reference- the dimensions for this one are at the top of the first data page -
616 engine.
Note the OM352 on top,
And then below it is the specific engine number that you are after. View attachment 2664735
2664746
Ok crawling underneath and in the wheel well and then by sure accident I found this on top of the engine, looks like it is a match for an engine ident.
U1450L DOKA
Yep, that is it. Good find.
They can be anywhere.
So, your proper dipstick is a Type D,
And
L1. = 824mm
L2 = 799mm
L3 = 28mm
Discussion Starter · #17 ·
Oh lol, had I read your post while I was outside could have save myself some time. TRUKTOR I really appreciate your time and resources. For my future reference, when I am talking about my engine what number should I quote.
U1450L DOKA
If it were me, I’d draw the Type D dipstick out, full size on a piece of paper or something. Then you could lay your type A against the drawing ( it could be a single line with hash marks at the L1,2 & 3 dimensions) and readily see what is what . Some times fumbling with a tape against something like a dipstick, especially a hinged Frankenstein version can be a pain.
Good luck.
Discussion Starter · #19 ·
Oh an apologies, it is
Good luck.
TRUKTOR thanks (tip of the hat to you sir) one last question, pretending for the moment my dipstick is fine, is the oil level to sit anywhere in that indent?
U1450L DOKA
Well, it is a OM352.
( the Turbo is the OM352A, the inter-cooled Turbo is the OM352LA)
But when ordering parts for it, or to determine the specifications of the engine (like horsepower, etc.), then the 353.961-10
Number comes into play.
1 - 20 of 38 Posts
