1973 416 Doka, 1978 416 Doka, 1980 416 Doka..... Help me, I can't stop buying them!!!
Since I picked up the 352A motor from a Beilhack snowcutter I have been gathering info and parts that I will need to make it fit into a 416. I should have most of what I need on the shelf. But I was curious as to the oil cooling squirter questions as to which blocks had them or the plugs for the squirters. I have read that blocks made after 78-79 all have them. Well I took off the oil pan on a block dated 1981 figuring I would see as least plugs. But it was not to be! I did find the high Vol. oil pump, which I will need the pick-up tube from for the pump in the 352A. I have attached some photos to show where the squirters or plugs would be if you have them. And a photo of the two different oil pumps.
1987 U1000
:mad: Well That's no fun ! I guess that one has to pull the pan regardless to verify squirting capability ....
While your high vol. pump is out can you post the p/n. just for the record.
GB
