My Operator's Manual is very specific about the FSS and A & B Services. Here are the specifics of each:
A-Service — First visit at approximately 10,000 miles or 1 year, but determined by Flexible Service System; then every 20,000 miles or 2 years.
Services performed:
Interior
· Function check
· Check warning and indicator lamps, illumination and interior lighting
· Check windshield wiper, windshield washer system, headlamp cleaning system
· Reset maintenance service counter in instrument cluster
Wheels, brakes
· Check front brake pads for lining thickness
· Check tires for damage, condition
· Correct tire inflation pressure
Engine compartment
· Change engine oil and filter
· Fluid level checks of the following:
· Engine cooling system, antifreeze and corrosion protection
· Windshield washer system
· Brake system
· Check and correct battery fluid level
· Check battery condition
· Check catch, safety catch and hinges on engine hood for proper operation
Trunk
· Correct tire inflation pressure in spare tire
B-Service — First visit at approximately 20,000 miles or one year after previous service, but determined by Flexible Service System; then every 20,000 miles or 2 years.
Services performed:
Interior
· Function check
· Replace dust filter (not applicable to SL-Class)
· Replace combination filter (SL-Class)
· Check parking brake (function test only)
Wheels, brakes
· Check condition/thickness of front and rear brake discs
· Check front and rear brake pads for lining thickness
· Check tires for damage and condition
· Measure tread depth, record in mm
Underside of Vehicle
· Check for major components leakage
· Check for chafe marks, line routing, damaged components
· Check condition of front axle ball joints and rubber boots
· Check condition of mechanical steering components and rubber boots
Engine Compartment
· Check and replenish all fluid levels
· Check engine cooling system, antifreeze and corrosion protection
· Check brake system
· Check power steering
· Check Active Body Control
· Check windshield washer system
· Check condition of poly V-belt
Trunk
