2002 SLK 32 AMG, bone stock. 1987 190E 2.3-16 valve (destroyed). 2005 E320 new toy.
You will need a six pack of oil. The standard recommendation here has been Mobil 1 0w-40.
1999 SLK230 2009 E350
The rated capacity is 6.1 qts. If you drain the oil through the drain plug, then 6 qts will fill it up. If you use a topsider or other similar device and remove oil through dip stick, then it takes 6.1 qts to bring level to the full mark. Obviously removing through the drain plug does not quite get it all out. Also assuming you are changing the filter.
