1 - 10 of 10 Posts
The filter I got from dealer comes with 5 O rings in 4 sizes. I heard I only need the largest one and two same size medium one, but dont need the two smallest ones. Is that correct? BTW, it is a C300.
Oh, and what filter do you usually use and where to buy? (other than dealer)
Thanks guys!
Thanks guys!
You are correct
Once you remove the filter you will easily see which O rings you will need.
Mike
2009 C300 4-matic Sport
Thanks guys!
Advanced Auto has a Purolator filter that comes with the o-rings and the filter is marked "MANN Filter - made in Germany" They also carry Mobil 1 0W-40 for $6.99/quart
2008 C350
Ok, I've searched over and over with no luck. Please someone help. Where is the oil filter and drain plug?????? I took off the undertray's.....I was lost under there. nothing looked like an oil filter or somewhere for it....or the drain plug. Can anyone post pics please? FYI--I'm not a rookie under the hood...just a rookie with MB. Thanks in advance.
Rob
2008 C350 and a Lightning.
Search some more, it's been covered pretty well in a few different threads.
The oil filter is on top, like a BMW. The oil can be extracted through the dipstick, with an extractor.
08 C350
Rob
Here you go, same as W204.
http://www.benzworld.org/forums/w203-c-class/1322384-diy-oil-change-2006-2007-c230.html
1 - 10 of 10 Posts
