2015 Mercedes GLK350 4-Matic, 2014 BMW K1600GTLE
Hello all,
I am curious, my manual says my 2015 GLK350 4-matic has an oil capacity of 6.9 quarts/6.5 liters.
Where on the engine check dip stick would this be? Would it be at the top most mark of the dip stick?
Reason I ask, I siphoned out 6 liters. I check the oil level prior and it was on the lower 1/3 of the dip stick.
Maybe the dealer did not fill it all the way up? I am doing the oil changes from now on.
Thoughts?
W163 Crash Test Driver
2008 ML350 (Me!), 2010 GLK350 (Wife), 2003 ML-350 (Deceased)
Definitely do your own oil changes. It's so easy, you know it was done right, and you'll save a ton of money over a dealer service!
Attached is more than you would ever want to know about the Mercedes Dipstick. :LOL:
I also attached the oil change procedure for good measure.
Thank you.
I believe my engine is a 276. Would you happen to have those guides?
You got it. And fill out your profile! ;)
1999 E320, 2000 E320, 2003 E320 Wagon, 2005 C230K SS, 2010 Accord LX w Eibach & Koni FSD's
You won't be able to drain/vacuum out all the oil. There will always be some in the passages and the oil filter retains quite a bit.
I like to have my oil level about 1/2 way between the two marks. No need to fill it all the way to the top.
I removed 6.3 quarts from the engine. The dip stick showed about 1/3 up from the MIN mark.
I added 6.5 quarts and its showing about 1/2 between MIN and MAX.
Max it takes 6.9 quarts. So, there is about 13 oz difference.
