1985 300TD, 1991 300D 2.5 Turbo, 1993 300D 2.5 Turbo, 1995 E320 Touring, 2006 E350
Hi--
I solved my hot start problems on my '95 E320 with a new fuel pressure regulator. I was talking with someone and he told me that I should change the oil because a faulty fuel pressure regulator can cause gasoline to end up being sucked into the crankcase oil and diluting the oil's lubricating properties. I just changed my oil about 400 miles ago and I'd hate to waste changing oil for no reason. Should I change my oil? The vacuum line on the fuel pressure regulator definitely smelled like gasoline, so I'm sure that there was gas in the vacuum line.
any help/advice would be appreciated
While I was going to school one of our teachers suggested pulling the dipstick out and applying a lighter. One of two results; a quick flash or nothing.
service re set.
Could anyone tell me, how to get rid of the service over due indicater which appears while starting the car. (E320 1998). It breifly disappeared after the oil change.
93 190E 2.3, 94 E320 (sold), 01 E320, 99 S320, 18 Durango
You are in the wrong forum, You need the W210 forum not the W124.
