Under the air intake ton the right side of the valve cover runs right next to it and into valve cover. A broken pcv valve will disperse a large amount of oily gunk all over the front right(if your looking at the engine) of the engine compartment. Just start your car, pop the hood, wait a minute or two if you smell a sort of rich exhaust it's a broken pcv valve.The oil cap is very tight, hard to get off, so that's not the problem. Where is the PCV valve located?
