1 - 13 of 13 Posts
300SD
Mercedes no longer offers the original style power antenna for the 123 sedans. The replacement direct fit Hirschmann antenna is part number 921504412. This antenna replaces the following OEM 3 antennas:
201 820 01 75
201 820 01 75 80
201 820 01 75 88
81-85 123 chassis sedans have the 201 820 01 75 OEM antenna, model AUTA 6000EL
Has anybody installed this antenna? Is it a good antenna? The antenna kit (DRP-5 kit) comes with accessory pack for different cars. For the 123 chassis sedans, it includes bracket adaptors, antenna tube spacer, and new connector pins, plus harness connector.
The instructions require that you take apart the six pin antenna harness connector, cut the pins off the wires, and solder three new pins on and insert into the new connector. Will this new antenna operate with the original antenna switch? I cannot figure out why they could not fabricate a simple plug in adapter to eliminate having to cut old pins and solder new ones on and modify the harness. Some engineering this is.
Administratoris Emeritus
2024 SL770
Don't do it -- it's a PIA. Just buy a universal Hirschmann (2040). It's inexpensive, at least as reliable as the OE, and it's a pretty easy install.
300SD
Why is the universal Hirschmann antenna better? Can you use the original bracket/plug with it?
2024 SL770
No, you cut the plug off to wire it direct. It comes with its own universal bracket. The antenna is no more than half the price of the one you're considering, and an easier install. The 2040 also features a replaceable mast.
Just repair your OE antenna! I struggled with this delima too, raiding junkyards and shopping for replacements, all with little luck. Then was referred to a gentleman in Burbank, CA (from someone on this board I think, thanks!!) and he fixed my stock antenna, good as new! For reference, my antenna is a 6000u and the telescope was replaced ... luckily I'm close so dropped off/picked up and he took about 24 hours, total cost was $140 ... not cheap, but stock and right!
Walter Odemer
818.846.2819
Burbank, CA 91506
Good luck,
Carl
1982 300CD
The PO of my gold car had a new antenna installed, but never had it hooked up. I bought a plug adapter for it for $35, and it works perfectly, even stops at half way according to button position. If you rewire it direct, you lose the half-mast functionality.
2024 SL770
Yes, you do lose the half mast thing, I've really never understood the value of that to start with...
300SD
What plug adapter and who sells it?
1982 300CD
It connects the "universal" antenna's wires to the Mercedes 6-hole plug.
Antennaworld.com sold mine to me. I tried to look for it on the website, but can't find it now. Maybe you need to send them an e-mail and ask about it.
I found a picure of it! Here you go.
2024 SL770
I had never heard of that before. That's really pretty slick.
300SD
Discussion Starter #12
Gregs300CD said:
Here's a guy in California who fixes them.
Probably the guy you were talking about.
index
I called him today and he wanted $ 85 for the antenna top fitting!!!!!:mad:
(if he could even get it). This part cannot retail for more than $ 20 in my opinion.
Tomorrow I will probably pick up another used antenna with a good fitting for about $ 30 in the local wrecking yard and that's that.
300SD
Discussion Starter #13
Update:
I got a broken 6000EL antenna with a good upper fitting from the local junkyard today. Ironically, the antenna came out of an Euro 500SEL sedan. They also had an early 80's 300D turbo sedan, but it had a completely different antenna in it (AUTA 6000U). Go figure.
Anyway, I got the antenna for $ 15 plus tax. removed the broken mast and fitting, put fitting on my old original antenna, mounted the antenna, and fed the new mast into it. Took a few tries, but it got in and everything works as it should. The new mast is from autohausaz.com and cost only $ 14 and change.
1 - 13 of 13 Posts
