281 - 291 of 291 Posts
'99 SL 500 Sport
So I've gotten 2 different answers on installing the Continental TR7412UB-OR - in my 99 SL500. The people at ECS Tuning tell me it's not compatible, but the folks at Caraudio24.de tell me it will work, with a inexpensive adapter. The radio is only 100 euros, which is much less expensive than other posters have said that they paid, so I want to make sure that I'm getting the right unit. Also, I understand that the electrical system changed for the 99's, so this is not as easy as installing in an earlier model. I've just inherited the car and am trying to upgrade a few things, so any advice is greatly appreciated. Thx.
1999 R129 SL500
I have been using it in my SL for just over two years. Cheap buttons aside (ask me how I know), it's a great unit that's pairs well with the 8-speaker BOSE unit + Subwoofer. Installation took me 2 minutes and it was plug and play. You'll notice there will be one bundle of wires that just won't plug in anywhere behind the Continental TR7412UB-OR - that's for the CD changer. Since you don't need it, you can leave it unplugged behind the stereo.
That's my experience. Very easy installation. No adapter for hooking up.
'99 SL 500 Sport
Are you able to stream music via bluetooth? What are you using for a mic? And how do you know that the buttons are cheap. Thx.
1991 500SL; 2014 GLK250 BlueTEC
I installed one in my '91, and it works well, including Bluetooth that pairs easily to my Google Pixel 3 phone for music and podcasts, as well as Google Maps navigation. My car has an original mike, but I couldn't find where the wire led to, so I used the one that came with the unit.
'99 SL 500 Sport
Is the electrical system the same on the '91 and '99?
I don't think so, therefore you should refer to what an earlier poster with a '99 SL wrote - it took him a couple of minutes?
My wires were already hacked up as the P.O. installed a later-model stereo, so I had to figure out which wire did what, and wire them all properly to the new unit.
1999 R129 SL500
Yes, I'm always streaming VIA bluetooth, using the mic built into the Continental - I could have plugged my in-car mic but I read that the Continental mic is good enough.
And buttons are cheap because one fell off. Good luck getting in touch with anyone at Continental if you have a problem - you will literally not hear back from them.
1997 SL 320 19.5K miles when purchased 11/2019
Has anyone installed the Continental TRD7412UB-OR (Has DAB/DAB+/DMB Tuner) instead of the TR7412UB-OR unit? A better question would be do all of the Continental radios install the same?
1997 SL500- 40th Anniversary
If the TRD is ISO and single DIN, I can't imagine there would be any install difference (unless a special antenna is needed?)
Thank you 'Ears" for your reply to my question. So thanks to this thread, I have decided to order the Continental, via Ebay from Latvia I think. I ordered the version which has a CD player and Bluetooth, etc. No DAB/DB+/DBM tuner since this would be useless to me. The reason for the CD version is not because it has a CD player. Rather, the aux-in plug is on the rear of the radio. I plan to remove the "brick" cell phone from its hiding place and install a Sirius/XM tuner, and I want to not have wires running from the Sirius module to the front of the radio. I should be able to power the Sirius module with the power that currently runs the "brick". I will post the results when I finish, probably in mid February, the store across the pond says the radio should arrive during the first week of Feb.
2002 Black SL500, 2000 Azure blue SL500, 2005 Silver (A209) CLK500
I was looking into the same radio...I want the USB port...I can plug in my thumb drive and listen to songs when I am in areas where there is no reception....
