My 1982 240D has only 99k miles on it.<br>Recently I have noticed that the trip odometer<br>locks up usually as the 1/10 mile number turns past 9.<br>This causes the odometer to stop registering total miles.<br>The speedometer works normally. <br>Has anyone ever had this problem and is there a solution?<br>Thanks. Jacques
Discussion Starter #2
Mine did the same thing. There is a small plastic gear that drives the tripmeter & odometer off of the speedometer. I called two speedometer repair shops listed in Hemmings and both wanted $125 to repair and will not sell gear separately. I'm looking for a good used spedometer unit now.
my 300d's odo stoped 3 years ago at250717km since then im sure we have done well over 150000km in addition<br>QUOTE<br>'IF it doesnt affect the performance of the car<br>DONT WORY'<br> louis miles
Re: Re: odometer problem
In SA you can buy those gears from the MB Agents.(For about two dollars if I remember correctly)
I have fixed a couple of odometers for 116 cars with a drop of Loctite 680. One of the gears starts slipping on the shaft, and a drop of loctite will fix it. Use Loctite rather than super glue or something like that. Loctite only hardens when it is in a confined place with no air. It will not glue your fingers or other gears together. <br> <p>host162.servos.com
2005 w203, 2013 Town & Country
Thats a good idea and exactly what happens the gear slips...
I drilled mine out and "staked" it with a press fit rod.
you have to stop the slip
Jake
but yours locks up...hmhmhmmhmmm
did you take it out and look at it? if not yet be care ful of your eddy current needle and cone -other than that its cake...perhaps is just dirty and gummed up, or it is the gear issue and thats why it wont register, its slipping - ive done so much to my car its hard to remember reason and rhyme.
