1982 300CD
But, you probably won't have to go through all that trouble of taking the shaft apart from the number wheels and magically putting glue in there (which is almost impossible).
When you pull the shaft out, only take it out 1/4 inch. Then squeeze down on the shaft with a needle-nose vice grip a couple of times to bite some grooves into the shaft. Then, just squeeze it back together.
