'06 SLK55, '08 ML320 CDI, '08 GL320 CDI
I noticed that my rear turn signal light and the right license plate light is not working. I tried checking the bulbs, and the contacts. The contacts are not getting power. Also, i checked the fuses and all of them are good. It seems like an odd problem that only 2 bulbs are not getting power. All other lights work. Any help would be greatly appreciated. Thanks in advance.
2004 SLK230 Kompressor
Hi Vegeta,
Did you ever figure this one out? I am also having issues with the rear turn signals not working. All the other lights work.
Moderator
190E, SLK350
Use a multimeter and see if you're getting a signal to the load (lamp)
