All,
I have a 91 500sl with recently rebuilt cylinders. I lifted the top into the fully up position, did the sync process, everything locks into place. Even the top button goes off and appears normal. When trying to lower the top, things start fine-windows lower, things unlock, but the bow never lifts out of the way of the toneau cover. If I manually lift the bow to the up position and then return to lowering the top, all goes as designed. When trying to close, windows go down, toneau cover unlocks and lifts up.then the top starts to lift, but lifts maybe a third of the way up then goes back down. If I hold the button the top will go up and down in this part of the cycle, never proceding further in the process.
I cant see any leaks from any cylinders or lines. With top up or fully down, the top button no longer glows.
Any ideas on whats causing the odd behaviors or how to fix is greatly appreciated
