Any luck with the codes you were pulling? I have the same codes along with P2006...Thinking it is the MAF that needs to be replaced but want to feel a little better about it before spending the $300.00 on the hunch.Hello,
Is anybody know what's related to P2187/2189 "system too lean at bank1 and 2" OBD code ?
I cleaned my MAF and put it back in the car and still had the same codes (P2006, P2187, & P2189) even after clearing them. So i went ahead and bought a new MAF over the weekend and it jsut arrived today...the codes P2187 & P2189 are no longer present...so if you arent able to clean it then you might have to replace it...I have the same issue, bank 1 and 2 is your o2 sensors pre and post cat from what I have read. If I remember right it could be a vacuum leak. there is plenty of stuff on here about it. As for the maf try cleaning it before you replace it! I cleaned my maf, but havent cleared the code so I dont know if that fixed it.
Bit confusing.members have found a way to "manufacture" replacement parts.
On the other hand, reports from a fellow forum member and MB tech (a02stang) is that parts of the intake manifold can break off....
so I am not sure I'd go the "repair" method.
Amazon.com may be selling a new oem Bosch one for about $100-$110.Thinking it is the MAF that needs to be replaced but want to feel a little better about it before spending the $300.00 on the hunch.
I don't know the detailed failure mechanism of intake manifold failure on C230. Is it cracking or mating surface to the cyl head failure or gasket ???Certainly hope that's not the case. How would one even diagnose that?
Go to MBWorld for help. BenzWorld is dead!I have a 2006 R350 3.5L with the P2187 & P2189, P0300, P0304, P0305, P0306 at 1500-2000 rpm it ran fine but at idle it acts as if it's going to shut off but doesn't so I did a compression test on those cylinders which so I did some research on line and found that there are 2 timing chains and tensioners that 1 may have become weak causing the chain to slip throwing the timing off on that side hence ruff idle multiple miss firers except at higher rpm. Now I haven't tested this theory yet but it does make since to me so I'll have to pull the covers to check the timing marks. I'll get back to this forum later. just something to think about good luck.
I drive 2006 C280 Mercedes BenzI have a 2006 R350 3.5L with the P2187 & P2189, P0300, P0304, P0305, P0306 at 1500-2000 rpm it ran fine but at idle it acts as if it's going to shut off but doesn't so I did a compression test on those cylinders which so I did some research on line and found that there are 2 timing chains and tensioners that 1 may have become weak causing the chain to slip throwing the timing off on that side hence ruff idle multiple miss firers except at higher rpm. Now I haven't tested this theory yet but it does make since to me so I'll have to pull the covers to check the timing marks. I'll get back to this forum later. just something to think about good luck.
Can you provide website or link to buy it ?I cleaned my MAF and put it back in the car and still had the same codes (P2006, P2187, & P2189) even after clearing them. So i went ahead and bought a new MAF over the weekend and it jsut arrived today...the codes P2187 & P2189 are no longer present...so if you arent able to clean it then you might have to replace it...
can you provide website or link to buy it ?I cleaned my MAF and put it back in the car and still had the same codes (P2006, P2187, & P2189) even after clearing them. So i went ahead and bought a new MAF over the weekend and it jsut arrived today...the codes P2187 & P2189 are no longer present...so if you arent able to clean it then you might have to replace it...
