So, investigating further my lambda readings on one bank of the M120
Two weeks ago, after gutting the passenger side cat, my lambda went to 50%, and varied a bit, as it should.
Today, noticing a rich exhaust smell, I checked it again. Steady at 70%. No voltage fluctuation. Up on the jackstands it goes again.
Ran a wire from under the hood to the connector for the passenger side 02 sensor. I'm showing continuity between all 4 pins on the 02 harness socket and pin 3 of the X11 connector on the fenderwell. This tells me I have a short somewhere in the harness.
As I don't have wiring diagrams, I'm not sure where to begin. I think I'll replace section of the harness. But with a 4 wire harness, that represents a heated O2 sensor. My new ones are not heated; nor were the old ones.
Where do I start tracing the wires? And can anyone assist me with a wiring diagram? I want to know the interconnections between the X11 diagnostic port, the LH compter harness and the O2 sensor.
Regards
Regards
