97 S500, 99 e320 4-matic, 06 Q56, 57 Ranchero, Sold: 95 s320, 90 300TE 4-matic, 82 380SL, 71 3.5 cpe
I was wondering - if I take a brand new Bosch O2 3-wire sensor, hook up the 12-volt heater and the sensor wire, and shove it up the tailpipe a few feet, should its output track the behavior of the one under the passenger seat? I was thinking this might be a good way to tell, once and for all, if the installed one is good or not.
Thanks,
Tom S.
2016 535i, 2019 Q5
No because you are getting post cat behavior...
A new o2 sensor is ~$40 if you splice it in...its not worth the time diagnosing.
O2 replacement
I do have the replacement part - but I also have a bad back and am reluctant to do the physical s#!7 to replace it without being 100% sure that's the problem :)
· W124 Moderator
86 190E 2.3L 16V, 95 320TE 02 S500
Tom
O2 sensors have a general service life of approximately 60M miles. That would vary depending on how well the fuel/air/ignition system of the car was maintained.
Your best move is to replace the sensor.
Jayare
Sent from my DROID2 using AutoGuide.Com Free App
92 400E, 95 S500,91 300TE practically stole it, 97 V10 Ford E350 to tow them home from time to time
I too have a bad back, my neck is screwed together. It's not that bad of a job and you can use your foot to loosen the sensor.
