I’ve just installed a new aftermarket amp and radio. It was just working the other day and now, there’s no power going to it. It doesn’t turn on at all. I already checked all the fuses and they looked fine.
2000 ML55 sold? 2013 ML500,? 2015 C250 estate wagon, 1927 Dodge 4 sedan, 1929 Dodge
You might need to check your wiring to it.
Check the voltage at the plug going to the unit.
Also check you have voltage on both sides of your fuses.
1999 ML430
If you have verified that your power supply is good to the radio/amp and you made sure that the radio itself and the amp are turned on.....you must have a defective amp or radio.
Need a good ground also.....let us know what you find out.
Moderator
Welcome swaebrian,
Fuse on the radio? checked?
check all wiring connections.
Please update your user cp info:
click on your icon----> click on Account Settings---->
goto Account Details----> add vehicle details---->
add your make model YEAR ----> click save
Welcome swaebrian,
It turned out that the car was dead. After I jump started it, the radio came back on lol. I hope this forum will help someone else who would have this issue, thanks 🙂
Describing that you had no start or dash lights might of helped us point you in the right direction.
