1 - 20 of 26 Posts
'76 1300L,HE351CW,H15P Winches,Konis,Hydraulics,All Gears,10mm Plungers,Aftercooler,Lots of Littles
Well, the debate over buy or build a camper for the back of the UNIMOG is now over. I joined the ranks of the Alaskan Camper owners this morning. (Actually I have been an owner for a month, but only today did I lay my own eyes on it).
Special thanks go out to Merz-Ben, NeedaMog, and Mike Pop. I really appreciate each of your contributions to getting the camper into my possession. I owe each of you a beverage of your choice.
The camper is in very good original condition. A little winter work and it will be ready for use next spring.
C.
Discussion Starter · #2 ·
This looked less scary at the time....
C.
1975 404 Doka Unimog
Awesome. It's off topic but I see that you guys often use timber floors on trailers whereas we only see steel floors here. I wonder why ? Are they cheaper to build, lighter or is it just tradition ?
Nice camper too. I'd like one. It would save me pitching a tent !
Discussion Starter · #5 ·
You can get steel trailers here. I prefer the wood decks.
1. Easier to walk on when wet. Steel gets way too slick.
2. Quieter.
3. Does not dent if you haul rocks, and easy to replace.
4. Quieter.
I believe wood has a better compressive strength to weight ratio too.
C.
1978 406.120 1977 416
Alaskan
Wow congrats, that looks like a very nice shape modern one.
Do you have any Idea what it weighs and what year it is?
And yeah some interior picts. would be cool if you get the chance.
A while ago I got a 1974 8' cabover for my 75 power wagon.
Sure do like it... a bit heavy, but all wood interior, no press board at all.
One day I will have to put it on the 406 cabrio just for fun.
Well again congrats, not real easy to find, and it looks like it is in great shape!
Best
Slothmog
Discussion Starter · #10 ·
Exterior and most of interior is fiberglass. Almost no wood in this model.
I have been told they are 1500 lbs, but I really have no information to back that up.
C.
230G, U1200 Ag, 1017A, lots of MB cars, Volvo c303, 416 raildoka, LR D110 TDi
By the load it was on my little loader tractor, I would estimate it between 1500 and 1800 lbs. It was at least as heavy as a 1500 lb round bale.
Discussion Starter · #12 ·
Is that your tractor? Is it coincidence or do you like blue machinery? :p
Nope, while I do have a Blue Tractor (Ford 5000), that one is Ben's. Mine is loader-less.
C.
Edit: I guess that is obvious from Ben's reply above. Must have been sending it at the same time.
Discussion Starter · #13 ·
Getting slowly around to doing something with this....
The outside is now in White Primer (I hate woodgrain...)
Vehicle Travel trailer Trailer RV Horse trailer
Some woodgrain to repaint on the inside, but going to keep the stock wall paintings.
Vegetable Botany Watercolor paint Still life Still life photography
Property Room Wall House Ceiling
Sink Vehicle Room Car RV
Good condition overall, 2 main mechanical issues to deal with. The rear guides and top/bottom seals need to be replaced.
Wood Floor Room
These will be fixed by installing proper nutserts and machine thread fasteners.
Door Architecture Wood House Window
Wood
Also, someone tried to fix the mount for the front passenger hydro cylinder and did a nice job except it is about 30mm too high. Will have to correct that.
Motor vehicle Vehicle Vehicle door Mode of transport Transport
Tape measure Ruler Measuring instrument Rain gauge
C.
Discussion Starter · #14 ·
Besides the mechanical and painting, I how I get A/C and a proper fridge installed this summer. Also sleeping quarters.
Anyone want to share their thoughts on roof mounted RV AC units for this setup? Not sure how else I would do it...
C.
Discussion Starter · #16 ·
Power will be one of:
-Shore Power (Likely more of the time AC is needed then not, during the summer the most likely use of the camper is going to be in campgrounds and such. More remote trips are Spring/fall for us usually.)
-Generator Power
-24VDC/120VAC inverter system
Will have enough power to start a 13.5kbtu unit.
C.
85' U1300L Holset Turbo VA A/C, 66' Propane 404.1 rock mog, 1975 416 Doka, G500, Volvo C303
Shore power, good. Didn't know if you were going to try to run a large bank of batteries or something.
My suggestion, go grab a window unit from Home Depot that is sized correctly for the camper. Then take it all apart!!!!
They are brutally simple units, and they are easily packaged into a new box. Or actually multiple. Keep in mind you will have to add service ports as window units don't have them. But this will be easy as you will likely want to add hoses to separate the condenser and evaporator.
1986 U1300L; 1976 U900 Cabriolet
This is a topic that I have researched a bit while trying to figure out how to cool both the cab and the Krankenwagen box. Here's an eBay reconditioned unit for not a lot of money Dometic Duotherm RV Air Conditioner Brisk 13 500 BTU with Warranty | eBay
I looked at using a 24V (truck no-idle) style of unit for the camper box, but was told the volume was too large - that's why the caravan and RV units are 110V. Our problem with offroad trucks is that the rooftop unit is likely to get removed by the first low hanging branch. Also, weight up high is never a good idea. This one is my pick, but I cannot find space for the main unit ecowind1 - lombardinigroup.it
A small inverter type domestic split system with the main unit tucked under the camper overhang (along the side) could be an option. Probably easier to noise insulate than the rooftop ones.
Discussion Starter · #19 ·
Those Ecowinds look like the hot setup. Amazingly quiet.
Any idea how much or where you can buy them outside Italy (if you can...).
C.
1 - 20 of 26 Posts
