1983 300SD Turbodiesel
But what are the correct wheels(size, offset, etc) for an 83 SD? I can't find that info in the FAQ. Just like I can't find the info on the proper coolant, or trans oil in the FAQ either. I find the FAQ severely lacking in pertinent info like this. :twak: Actually, it seems to me a lot of newb questions go unanswered in there...
Anyhow, I know these wheels are wrong:
There is an 1/8 inch or les clearance between tire, and the steering linkage. What size tires are right to since I'm asking newb questions anyhow?
1997 SL500 40th Aniversary 1998 C230 2002 E430 sport 1987 420SEL sold 1989 300E sold
126 Ch 300SD 1981-1985 ran a 14x6 ET30 with 195/70/14
some people would increase tire size to a 205/70/14 as on the V8 models.
You can run a 15x7 ET25 that was used on 1986 and newer versions with a 205/65/15 tire.
The wheels that you have right now look the same as the 1986 and newer version, but they are most likely from a different model if they are that close to the suspension. Hope this helps
The proper coolant is from Mercedes part # Q 1 03 0002 ( slight gold color )
The transmission fluid is the Deron III, IV ( Mercon ) It is the red fluid ( I believe Ford uses or used the same fluid )
Thanks for the info. I already hade the trans oil info.
