1 - 11 of 11 Posts
Hi, i dont own a benz this question is about my moms car so i dont have as much info as i normally would if it were mine. but.......2003 C320 hesitates badly under 3/4 to full throttle. there is no check engine light on. i dont have service history but aside from normal tuneup stuff is there anything obvious that could be pointed out? i cleaned the MAF and air filters and it helped a little but still major hesitation here. thanks for the help in advance
i'd try changing the fuel filter because it is cheap. you can also try to scan the codes even if the light isn't on because there may be stored codes.
i thought about that as a possibility, not sure if it has been done yet but when i say hesitates i mean it feels like the ecu is pulling the timing back or a major vacuum leak, light throttle you dont notice it but anything more than half it gets bad
clogged fuel injectors or weak fuel pump are other possibilities. I'd think vac leak would turn on MIL but maybe not. you can try to run a bottle of techron through it. there are places you can send them to (witchhunter.com is one I've used for another car) and they can professionally test and clean them.
How many miles are on the clock? Anything over 100K and you may be looking at problems with the supercharger or clogged catalytic converters.
Oops, sorry - I must be getting dyslexic (getting old is a real PITA). I see - C320, not C230. And 81K is probably too early for cat problems, but it's still possible. So, the hesitation, is it only from take-off, or anytime you accelerate, even at highway speeds?
Lol, it happens at any speed, from a start or normal road speeds just runs like $ hit under sporting acceleration
2003 MB C320 4MATIC Wagon
paranoia?
I just got a C320 4matic two weeks ago. It was a great deal from a legit dealer, but i feel possible hints of the same thing happening to me (or im just paranoid because i DONT want anything to happen)... mine seems to only happen under light acceleration at low speeds. normally when i startup in the a.m.
Well, maybe I fixed it, took it on the highway and kick the $hit out of it, runs good now!
My mom puts 89 octane in too which maybe contributing to the problem
You know, this thread reminded me of another possibility. - the defective Valeo radiator that lets coolant and transmission fluid mix. Do a visual inspection (see this thread) and make sure you don't have that one.
1 - 11 of 11 Posts
