1995 MBZ E220, 5 speed manual
My E220 is in India, and I wanted to get some better headlamp bulbs for it.
Is the narrow light close to the grill a fog light? So should I assume that the main light has a two filament bulb for hi and lo beam?
What bulbs do I need for the main headlamp? Sylvania shows a 9003, is that correct.
This is a E220 that is left hand drive and is a 1995 model. Pic of headlamp attached.
Thanks for the help.
Hi benze220,
You are right, that one is a fog light.
The low and high beams are in the same bulb, a H4.
The fog light is H3.
For more info on what bulbs are on your car, go here:
Which lamp type you need
You just select what bulb you're interested in, then you are asked to select your car details.
Cheers!
Lamp guide
Great. Thanks for the info, finally a site where my car is listed!
