I pulled the driver's seat out. There are several broken springs inside the lower part of the seat (causing a loss of support on the left side of the seat). I thought about taking it to a professional upholsterer, but I figure with the broken springs it will run into $$ to get fixed. There is a hole and splitting at the seam on the upper part of the seat also.
I have found several seats (used) listed various places with fairly close color matches to the (I think it's called Palomino) MB. Wondering if I can easily swap out the seats (preferably BOTH front and rear to get a better appearance.
Wondering if anyone has done this (or run into problems with doing it)?
If I can get nice enough seats, it would make the interior look much better (along with a good carpet cleaning, etc).
Thanks!!
AFARR
'85 2.3-16 '99 C280 '11 GLK350
You'll need the brackets that attach the seat to the floor mounting points. Recaro and Sparco might have the brakets, or they can be custom made by a metal shop.
