1 - 10 of 10 Posts
S320
Hi,
I have recently bought a 2003 S320, and I was told that I needed to get either a Nokia 6210 or a 6310 phone to fit the built in car kit. When I plug the phone in, I sometimes get the message "Initialising Phone, and nothing else. If I have the engine running, and I try and connect the phone into the cradle, I get the message "tel not plugged". Am I doing something silly, does this combination really work, or have I got the wrong handset, any advice would be most welcome, and appreciated.
SLK 320 / CLK 320
I have an '03 CLK using the Nokia 6310i for 18 month now. I haven't had the problem you describe. Suggest you could check the phone cradle is properly connecting into the car's socket, and if that fails, get the software checked out by the dealer.
W124/230E, W202 C240 stationwagon, W210 E280 facelift
Try to ask the service workshop if the phone software version is suitable for system of your vehicle.[:)]
W203 modified
VicMistry - 5/15/2005 4:23 AM
Hi,
PRESS *#0000# on your phone and see if the version number is below 5.0 That might explain the issue.
Most Nokia 6310i phones for Benz have the latest revision firmware at around 5.5. For older phones the version number can be lower.
As far as I know nothing below 4.5 works
CL 55
Hi VicMistry
Did you resolve this issue. I have exactly the same problem. Have access to an old 6210 and this works fine. 6310i....same issue as you. Been told by benz service mechanic that a 6310i should work.
Cheers
2000 SL320, 2003 E320
Hi,
as far as I know it's a software compatability problem. Car needs to have installed software for the specific model of phone i.e. even 6310 software can give problems with a 6310i phone. Dealer should be able to upgrade specific software.
dealers cannot upgrade the phone software, you have to bring the phone like Nokia to Nokia service center for the software upgrade.
It's not the phones software that needs upgrading it's the cars. The phone's software would need to be downgraded which I don't think can be done.
1 - 10 of 10 Posts
