Hello,
I have a 1995 E320 Wagon about 235K miles, for about the past 6 months I have been fighting the problem of a noisy belt, It is always screaming at idle and at all speeds below about 2000 RPM. I have Isolated the problem to the Tensioning pulley. Here is what I have already done
Checked for leaks -no coolent leaks found and I haven't added any coolent in the past 6 months.
no oil leaks
replaced the belt 3 times, cleaning the pulleys each time with a brush clean rags and 409. origionally I had a continental belt, changed to a gates belt, no change,
2 months later changed to a dayco belt - worse!
changed back to a new Continental still squeeling.
Changed the tensioning pulley- no change I have been driving it regularly keeping an eye on the belt but I cant seem to see any wear on the back of the belt.
Last week while at idle and the belt squeeling loudly I shot a small amout of Baby powder on the back side of the belt Immediatly the squeeling stopped.
It returned when the powder wore off. Im out of ideas anyone ever had a problem like this?
97 SL500, 03 ML500, 88 300TE , 2005 E500 Wagon
Sounds like you may have a bad tensioner. Have you tried replacing it? A new one should come with a new pulley. I've been told they can be noisy when they go bad.
Todd
W124 Moderator
You can also take a short length of garden type hose and use it as a stethoscope to isolate the source of the squeal. From what you have described, it doesn't appear that the belt is your problem.
Good Luck,
Jayare
Black on Black S124 Estate and White A124 Cabriolet
I think Radio guy has it, this problem was fixed via tensioner replacement for me 2 weeks ago, my symptons sounded like your symptoms.
