1997 w140 s500, 1990 renault 5 gt turbo
hi
just bought ,a 97 s500, with 120k on it, and now its started ticking !
been reading up on how the oil guides are plastic , and break over time .
so i took off the right side cam cover , where the ticking was coming from , and checked all the plastic guides and chain guide ,and they where all in very good condition as where all the gaskets .
put it all back together ,so put some noisey tappet oil additive in ,and let the engine run for a bit, but still the noise was there!
any one else with this problem here?
not sure if it is a valve stem on the way out ?
lewis
1997 S 500
I expect you've been following a recent thread I began:
http://www.benzworld.org/forums/w140-s-class/1374172-engine-ticking-tappet-noise.html
In addition to verifying that the cam oilers/tubes/tappets are intact, it's critical to ensure that they're also unobstructed. Make sure nothing is blocking the tubes internally.
Also, how confident are you you've identified the correct side? I thought I had this nailed down too, but mine was making noise from both sides. Awfully hard to pinpoint in that noisy engine compartment.
good luck,
Mike
hi mike,
the ticking definatly comes from the right side ,nearer the back i think ,(drivers side in the UK ) ,its more louder when i stand near the drivers door!!?
well u could be right , some could be blocked , as i only took two of the guides out to inspect them ,and blew through them fine. maybe i should take them all out and see!
or maybe put some engine flush in before i change the oil?cleen every thing out?
if i cant fix it ill just take it to a merc garage ,and see what they say ,once and for all!!!
as its starting to do my head in!!!
SEC 600 V12 2dr COUPE (RHD) One of the chosen few.
It could be a noisy injector.. so before you go spending the folding, Get a long extension bar or a long screwdriver, put it on the engine near the noise and listen..if its a tappett it will be louder near the inlet or exhaust if not drop the injectors off one at a time, it will run like a dog but you might find the one, hope this helps, dont put flush in till you know the problem..
W639 Vito 110 CDI; Ponton 220S; VW Phaeton V10 tdi; 1995 S500 ex diplomatic car (gone)
Hydraulic tappets can gum up with age. Remove the tappets and soak in cellulose thinners overnight and flush, works on other engines. 4 cams, 32 lifters........
I'm not advocating this, but it has worked before.
Discussion Starter · #7 ·
cheers guys , ill try the injectors on my next day off!
ill let u know how i got on!
lewis
