1 - 10 of 10 Posts
2008 BMW 528i,1999 Lexus 400LS, 2014 e250 BlueTec
Rubbing and ticking noise when turning. It happens in stationary mode as well as in motion with steering movement.
Can somebody help?
nugent,
Thank you so very much. I believe it is coming from somewhere around fire wall. With the information I will see if I can take care of it.
2008 E350 110k, 2000 E320 143k, 1983 380SEC 240k
nugent,
You're welcome. I am interested in the outcome because I have a rubbing feeling/faint sound when I turn the steering wheel, only in cold weather. I think it is the issue as described in my previous post.
2002 E430 4-Matic
There is some sort of rubber o-ring or bushing near the fire wall. It is usually the cause of a rubbing/squeeking sound. Comes and goes with no apparent reason. It is a time consuming fix. Both our W210s suffered from it and I just let it squeek.
W219 320CDI -07 W220 320CDI -01 W210 270CDI -01 EX: W211 320CDI -04
Like figuero said, bushing of the steering shaft is common source, but it could be also the ball joint (suspension)...
12 GL450
It could be as simple as your shocks. I too had this problem. changed sway bar busings and still had this problems. When I replaced my shocks, the problem went away.
1 - 10 of 10 Posts
