I have a 93 400 sel and it is making a constant loud nawing noise that seems to be coming from the water pump pulley. I removed the pully and the noise is still there. Sounds really bad. Couls this be an engine mount?
SEC 600 V12 2dr COUPE (RHD) One of the chosen few.
Not really.. engine mounts dont make noise .. they have no moving parts..
S600L
I had a similar noise to yours and I thought it was the power steering pump.However when the main stealers did my head gasket they found a worn idler pulley!Standing at the front of the car it's on the top left hand side and its about3-4 cm's in diameter - the main serpentine belt runs around it but I don't know if you can see it with all the black covers on(this is for a S600L - other engines will be different).Also I had a 'clonking' noise whilst driving over uneven ground - this was the front right hand side engine mount.They are a type of hydraulic damper and mine had split causing it to knock.Hope this is of some help.[:)]
My noise seems to be coming from the fan area. I dont know if it is the clutch or the pulley on the water pump. I replace the belt tensioner and that did nothing. When i remove the belt, the noise is gone.
