I just replaced my front brakes and rotors and have a serious humming noise that kind of sound like a low flying jet airplane. First thing i did was loosen the seal on my wheel bearings and i thought it fixed it until 20 miles later it started again. so i loosened them some more and thought it was fixed but started again. Once it starts making the noise it continues and gets louder if I'm going fast. I'm starting to loose my mind adjusting the bearings over and over again. I figure it should be tight enough where the rotor turns freely but doesn't have any play when you shake it. The pads also seem tight on the rotors...
