1 - 9 of 9 Posts
I have read that many of us readers here on this forum run sport bilsteins with their H&R sport springs, but i can't seem to find any, besides the koni's or regular HD..I would really appriciate if someone could tell me where they got theirs.. I looked at all the regular spots where i do my online shopping.... But nothing!!!!!! thanks Vin
2000 E320 Estate 199 2002 E55 040 Ford F550 Work
Bilstien Sport Shocks
Hey Vin
I was looking for new shocks for the Estate this AM. I found a set close to me in Fountain Valley on Ebay. Priced @ $379.
Also eShocks has a set. About $382.
Part # BE3-AO57-HO Fronts
Part # BE3-AO58-HO Rears
Hope this helps ya...
So you know the Bilstein reference book is WRONG on replacement HD shocks, and gives incorrect part#'s, so I strongly suggest you do more detailed research before you order specific part#'s in to do the job since you don't want to end up very very frustrated.
There is a search feature at the top of this forum, use "shocks" and wade thru all the available info including this post:
http://www.benzworld.org/forums/w210-e50-amg-e55-amg/1522492-w210-suspension-lowering.html
sweet thank you very much for responding swim wagon,YES I did a lot of the research and i am getting sports not HD's and yes i am putting the 058 on the front and the 057 on the back.. So again i will be ordering those as soon as i can so thanks again to both of you guys......
Thoroughly Confused
After reading Fabris response, I was confused. But, I crave the knowledge to better my Benz. I think I got it.
Bilstein HD shocks for standard OEM spring height
Part# B36-2156-HO Fronts
Part# BE3-A056-HO Rears
Bilstein Sport shocks for lowered spring height
Part# BE3-AO57-HO Fronts
Part# BE3-AO58-HO Rears
This is the Bilstein recommendation. However, this will make your ride appear to "nose dive". Installation should be reversed to "level" the ride height.
I hope this helps.. And thx Fabbris for the heads up.
On the HD shocks, yes the Bilstein reference is wrong - rears are listed as fronts, and fronts are listed as rears, that was well documented by Heindrich:
http://www.benzworld.org/forums/w210-e50-amg-e55-amg/1451023-confirming-bilstein-hd-shock-absorbers.html
It can be "assumed" the Sports are similarly reversed, but that is a assumption. I would suggest a PM to Mark Cummins ort checking on his source for the Euro shocks referenced in the post in my original reply.
As to the OP's comments thaty "many" E55 owners run H&R lowered springs, I really feel that is a minority.
On lowering, I would really suggest deeper investigation especially when it comes to rear camber.
There have been members who have done the full job, and I would suggest sending them a PM to get the full scoop.
On any W210 E55 with sunstantial mileage, lets say over 80K, I would strongly suggest the front ball joints get checked first as well. Fresh front ball joints will do a LOT to help front end control especially on the lowered suspension.
Keep the faith !
Normally, at milage its the worn front end components that give the "roughness" - the OE shocks (HD equivalent) without damage/defect are good way-way out - its the front end components that wear first, easy to check up on a rack for play.
Keep the faith !
2000 W210 E55 AMG, Silver/Black - Stock
Keep the faith !
OEM E55 are Bil HD? WOW! I take it back, seriously. I've used them on other cars with H&R and they were pretty brutal.
1 - 9 of 9 Posts
