1 - 18 of 18 Posts
I inadvertently changed the coding string on my 2008 E320 Bluetec and now the car won't start.
Any help would be greatly appreciated.
Super Moderator
How did you change the string and with what programming device did you do it with?
I didn't actually change anything but opened the variant coding according to factory data and pressed f2 instead of f1. The car was running at that time. Ignition off and back on as requested and changes must have been made. I currently have the battery charging and will attempt to start again but I am at work now.
I have a C4 that I was utilizing
W212 350CDI -09 W219 320CDI -07 Ex:W220 320CDI -01 Ex:W210 270CDI -01 EX: W211 320CDI -04
I believe your CGW needs fully coding again.
Discussion Starter · #6 ·
I went into control units, drive, cdi 4 cdi 5 common rail diesel injection, control unit adaptations, variant coding, variant coding due to factory data. Again I didn't change any values but it had me wait turn the ignition off and back on.
Do you know what these values are, what they mean and what I should do?
Oh I believe you reset your engine ECU to factory values then... can't see why that would prevent starting, unless engine ecu is not visible in can. You might try to check can configuration first.
Be careful what you do next, you may not be able to revesible actions without help of factory connection OR other softwares (and their pro user)... I can't help much because I just recently found that Xentry cars are pretty difficult to do anymore easy codings, because almost everything will need SCN... it was way more easier with DAS system.
Unfortunately no way of knowing what all ecu options are in your car, I believe you will need now to do initial setup of your ecu. And I truly hope that action won't need online access to SCN code string (it might well need that, because in Vediamo CRD unit changes usually need seed codes too).
You could try to find a fellow familiar with Vediamo or Monaco to code your ecu back to life. (Do you have those softwares installed? I am just about learning very basics of these, their usage is much more complicated than xentry, and much much easier to make harm than Xentry)
Last action if nothing helps is get you car towed to dealer and ask them upload the ecu...
Edit: I recommend try everything in simulation mode first (in DAS or Xentry) before going real action. It is true that not all option are possible in sim mode, but sometimes it helps.
Try find out if starting is authrorized... or where permission signal stops...
Das -> control unit -> body -> EZS (or EIS) -> Live data -> Drive authorization
Post a pic of the live data.
Clearly you must have changed the variant coding somehow, because obviously because the car doesn't start.
Then go to:
Das-> control unit -> Powertrain -> CDI 4 -> Live data -> drive authorization.
Also read the codes in the ECU and post.
In the same menu, go to control unit adaption -> view coding
Post a pic of that.
Then go to:
Post a pic of that.
Im having the same problem went into drive authorization and everything was saying yes
Then go to:
Post a pic of that.
So permission to start is ok. Have you tried direct voltage to starter? Sometimes they go out of blue...
Yes i jumped power to the purple wire on the inside underhood fuse panel and can turn the engine over but it will not start.
But if purple wire has no voltage, command to start is not coming right.
What engine you have?
1 - 18 of 18 Posts
