i was having repeated cold start problems it would start and die a few times then eventually stay running at idle couldnt touch the gas for ten min or so then it would run ok after that. no it died at idle today and wont start i have fuel to the fuel dis but not at the injectors any ideas what would have cause this thanks
· Outstanding Contributor
2005 SL600, (2) 2003 SL500
...i have fuel to the fuel dis but not at the injectors...
Does the mixture control unit flap move freely? If so, and it deflects while you crank the engine but there is no fuel going to the injectors, then I would suppose either: (1) fuel pressure is very weak due to defective pumps or fuel filter, or (2) the fuel distributor has a defect and is somehow not passing fuel.
My advice to anyone with a drivetrain issue is to search this forum and maybe submit a new post there, as peachparts is much larger than this R129 forum.
I have a good, used mixture control unit from a '92 300SL available for sale. Email me if you are interested.
about my no start problem
are you referring to the dome shaped flap at the top of the fuel dis for air intake? it is not moving sems very stuck what causes that can i just take it apart and free it up or what thanks for the help btw
me again
hey i forgot to ask do you have or know where to get the lighted trim pieces that surround the headlights mine are all busted up
