Well hello folks, I guess the title sums up my mood right now.
The subject is my 2000 ML320, 31k miles, bought it new.
Yesterday, without warning, it died about a mile from the house. It misfired for a few seconds before it died, and then it was/still is dead. I towed it home with my trusty 1951 Farmall Super A tractor.
Here is what I have done so far/some facts:
1/2 tank of fuel, with 50psi of fuel pressure at the rail, leaks down to around 42psi after 30 minutes.
Stored codes show P0300, and also individual misfire codes for every cyl except one(I don't remember right now). Freeze frame data shows rpm of P0300 to be 545rpm and open loop.
Checked all pertinant fuses.
I replaced the crank position sensor about an hour ago with no change(bought at local dealer).
The cluster does not showan error code in the odometer display, and the red led lights up under the low range switch.
The only thing I can think of is that the CPS has to be reinitialized, I could probably borrow the tool to do that or use my MT2500, but stup!d me can't find the round diagnostic port under the hood.
Any thoughts are most welcome, I really need to get it fixed asap because my wife uses it as her daily driver now.
Getting it towed to a dealer/shop is almost impossible, we live way out in the boonies. I don;t relish the thought of the bill or possible damage done by the tow company.
Thanks for any advice you folks can give.... talk about a head scratcher......
