Currently 2000 E320 4matic,118k miles, 1997 E300D 266,000 miles. Previousl.1986 SL560, 1997 SL500
I have a 1999 W210 with Bose sound. Just put in an aftermarket DUAL radio. got a wiring adapter. Bluetooth on new radio didn't work so I replaced it with a JVC. Now none of the speakers work. no pops, crackles or rattles, nothing, just dead silence. The radio is working in all modes but no sound comes out. Any ideas would be appreciated.
2000 ML320, 2008 ML63
Check the wires leading to the speakers from the back of radio and also check if there's a fuse in the back of the radio some have a fuse, maybe it was blown.
Sent from my iPad using AG Free
'01-E320 & 02-ST2
I'd start by plugging the OEM radio back in and see if you get anything.
Fixed it! thanks for all your suggestions. The am/fm amp connection was wrongly identified as a 'remote' connector in the installation instructions. Everything's fine.
'01-E320 & 02-ST2
Technically the instructions sound correct. The amp doesn't come on without a "remote" signal from the deck that it's on, so it is a remote connector. Same kind of idea as a remote signal for a powered antenna.
Glad to (ahem) "hear" you have it all squared away. ;)
