2006 E320 CDI 2009 E350 4Matic 2012 CLS 550
Hello all,everything else works fine with the command even dials out when I tell it to call home just no sound at all from anything all fuses are fine.I pulled the Amp out and checked all the fiber lines all is good but should be being it sees all the components in the loop I am thinking the amp died just wondering if I may be missing something...
Thank you Don
2012 e class, roush mustang
with that d2b it could be anything. would be nice to pull codes and see what responds and what doesn't. possible sound amp. try disconnecting the battery for a few min and see if it comes back up. I think you would also need a radio code if you disconnect the battery....not % on that
Current 2017 GLE350, 2007 S550, 2002 S430, 1998 ML320 Deceased 74 240D, 92 400E, 97 E420, 13 GLK350
The mercedestechstore.com has a training and troubleshooting module for the fiber optic db2 ring.
S320 w220 ; S500L w221 ; CL500 w215 ; CL500 c140 ; 208D ; 609D
Thank you Don
I had same problem with my s320... All components ( COMMAND, CD changer, TELEPHONE module, Voice control unit, and AMP ) are connected with d2b optic cable,,, If one of those component doesnt work, whole sistem wouldnt have sound.. So, you need eliminate all, exepct COMMAND, Voice contol unit, and AMP)...
Car need those 3 component to have sound... another components are not matter..
If than you have sound problem is in other components(CDC, TEL,I m not sure if TV is included)....
If dont have sound, than is problem in COMMAND or AMP or voice control unit...
Also you can test d2b cable...Take some light on one side of cable, and if you see light on other side, d2b is OK..if there is not light , d2b is broken.. and do that with 3-4 d2b cable..
· W221 & Audio Moderator
2015 S550
It doesn't have D2B, it has MOST - but the corrective procedures are the same. If removing components for the ring, different types of connectors are required for splicing either bus.
