just bought a 1990 190e. everything works except the right rear power window. took out the center plate(around shifter) and hooked up a test light to check for power on the switch. got power, checked the plug for the switch at the door, no power. okay i took out the passenger floor mat popped up the covers and started tracing wires from the door post foward.lost the wires at the firewall. tried to trace the wires from the center switches which the harness looks to go back along the transmission tunnel but could not get the center console off to check. this is where i am stuck at and any ideas on what to do next or what to try ,check would be greatly appreciated. thanks
