OK. So its the DCM. Should have researched better. But can i fix this myself? Where is it. Should I check the fuse or disconnect the battery as some have suggested?
Check out the photo in this URL. Shows the part number.Does anyone know a OEM part number?
This just happened to me this morning but on the driver side door, I turned on my car to warm it up and I pressed the seat warmer and nothing turns on, I lean over to passenger door and it worked fine. Then I try to adjust driver seat and nothing then I try the windows and nothing, mirrors also didn’t work. So EVERYTHING on driver door is not working, I cannot control any of the windows from the driver side but they work fine with their corresponding doors. It has been raining a lot these past few days could it be water damage? Also, is there anything I should check before replacing or is that the only solution? Since it is the driver side (with more controls than passenger) is there anything else to replace? Any help will be appreciated, I just got the car a month ago so I don’t know a whole lot about it.
Oh and this is also a 2000 S500
it didnt work for like 2 weeks, if it was just wet wouldnt it had dried by then?I'm certain the forum would live to know what your friend did to fix it (sounds like it may have gotten wet, and he dried it out - but that's speculation. It works if you haven't already fried it). Could you ask, and post the result?
