Hey y'all:
I've used the search function, and have found some _similar_ issues, though none are exact. But they've helped me come up with a couple things to check.
I'm hoping for a little help from y'all with more experience?
'99 ML430 with 210k miles, in very good running condition. I've owned this car for 3 years and 90k miles. Have never had trouble with the heat before. This has been a very warm summer (obviously!) but the temp on the dash-gauge has remained consistently in a zone that seems quite normal. Possibly related would be the idler-pulley that went on me two weeks ago, flinging the belt off at highway speeds. The belt actually flipped around enough to break the fan shroud, but everything else seemed intact.
This morning, went to use the heat for the first time in 6 months, and it won't get warm. There seems to be NO CHANGE in air temp, no matter the position of the control dial.
Coolant level is good. Temp gauge reads normal. I reached-in and grabbed the heater-core discharge hose (where it connects to the aux pump) and it is warm to the touch (though nowhere near as warm as the radiator hoses, for instance). I'm working, so I haven't reached all the way in to feel the supply hose for the heater core yet.
I've searched around this forum, and I'm looking at two places to start my troubleshooting:
1. Blockages in the heater-core supply hose.
2. Blend-door motor.
Does any of this ring bells for anyone? Am I on the right track here? Anything obvious I'm missing?
