1 - 8 of 8 Posts
v230
hi all, ive only had my 99 v230 early dash for about 3 weeks now but the fuel gauge says empty no matter how much fuel is in the tank, when i turn the ignition on the needle moves from below zero to zero and the warning lamp comes on for aprox 3 seconds and then goes off but the lamp does not come on before you run out of fuel as i have found out 3 times now very frustrating as i dont want to keep a full tank of fuel all the time, ive had the tank down and there are 4 wires a thick red/yellow 12v for 3 seconds then a constant 4v, a thick brown earth, a thin blue and black and a thin brown. does anybody know what to short to test the dash gauge as dont want to replace the sender if the sender is not faulty also does anybody have a dash cluster wireing diagram?
2000 108CDI, 2007 120 CDI long, Suzuki K5 GSXR track bike, 2005 Kawasaki ZX10R
Hi ya, you are after the blue/black and the thin brown according to the wiring diagram
Martin
v230
which one can i short to earth to see if the gauge moves at the dash end and does the thin blue black go all the way to the dash cluster without a colour change? if it does change colour at the dash end what colour is it so i can fault test the dash cluster if shorting at the tank end fails? regards Richard
The wiring diagram shows both wires going all the way to the dash cluster but its not the best wiring diagram that i have ever seen but getting wiring diagrams is like searching for rocking horse s**t
Martin
v230
ok so now im confused!!!!!! I have tested the dash cluster by earthing out the blue/black wire and low and behold the low fuel lamp comes on and the gauge reads full, super the dash works!! right back under the motor and i do the same by earthing out the blue/black wire but nothing on the dash, brain wave it must be a brake in the wire???? multi meter out ant there is no connection from the tank to the dash so i have run a new cable from the sender to the dash but now ive got a constant fuel warning lamp and fuel reading zero, ive just been and put £15 in fuel in to see if it was low or not but the warning lamp is still lit!!! any one got any ideas?????
Knackered fuel sender unit would be my guess, take it out and see if it works
v230
ok all i have done is run another wire alongside the blue/black as im assuming there was a break in the wire because when i earth it out at dash end the gauge reads full but if i earth out at the tank end the gauge does nothing, which to me says there is a damaged wire ie the blue/black, if i test the the blue/black with my multimeter the display does not read zero as it does when i put touch both wires together on my multimeter indicating a circuit.
so in short how can replacing what looks to be a broken wire point towards a dodgy sender, i dont have the time to take my tank down to test the sender then refit and take down again at a later date to replace as it is in daily use with our disabled child.
could running the second wire be causing the increased voltage to light the fuel warning lamp?
1 - 8 of 8 Posts
