My 300cd hangs me out to dry on occasion because my tranny doesn't kick down a gear when accelerating. Any suggestions?<br> <br> Bruce
Discussion Starter #2
Try turning off the power emergency brake (the AC).<br> <br> Check to see if your throttle bracket is in good shape, sometimes it wont give the transmission the full swing to engage the kick down.<br> <br> Move the shifter to second.<br> <br> Austin
Could be as simple as the carpet rucking under the throttle pedal.<br> Or at worst the adjusment on the activating leaver on the side of the gearbox is out.<br> Happy motoring,<br> Bruce
1982 300D
I found that my well worn Fuel pedal was not pressing the kickdown switch behind it. ...
I found that my well worn Fuel pedal was not pressing the kickdown switch behind it. So I added a peice of dense stick on foam under the pedal. This made the switch activate a whole lot easier. No longer did I have to smash on the pedal to make it kick down, now it only takes normal pressure.
Shane Kullman
'82 300D Silver
