while i was checking vi/wt wires i tapped on mas control unit and car started. removed mas unit and starter still cranks. would like to know if mas could be the problem. i do know of a tsb about neutral ss harness problem but i think problem is close to mas unit. any suggestions would be helpful.THANK YOU ,Bruce
Greek God of the R129
SL500-500SEL-190E
Also ck the wire connector under the MAS
Before you spend $$$$
Regards.
aam.
