1 - 10 of 10 Posts
· W203, W210 Moderator
E55 ///AMG
I finally got my new tires installed!:D and so far it's stickier than the PS2's but will see so far it has only 20 miles since yesterday. I still got my existing PS2s, still has a lot of thread life in them and still looks new. The shop did an 4 wheel alignment of course (new tires) but was impressed with the existing alignment condition of the wheel alignment before the adjustment. All they adjusted is the front toe which was off spec by -0.02deg. the total Front Toe is 0.18deg (dead center) Rear Total Toe is 0.43deg (almost dead on center by 0.03deg! and the total for the Trust Angle is 0.00deg! hahaha not bad for a lowered car set-up at all even the other guys that are watching said is that accurate? LMAO. I sanded my break rotors and repaste all four of my break pads since nobodys using the lift that day. So far I'm very happy with the handling of the car. I'll do a review after I put some miles:D Btw, I love the new valve stem I got from my friend that he got from Germany.
'04 SL 500, '03 BMW M5, '03 BMW 325i,
Damn! Those look pretty agressive! What is the "expected" mileage and how quiet are they? I suppose only time will tell...Have fun with them but take it easy for the first one or two hundred miles.
E55 ///AMG
Yes the thread pattern has a unique design. The Invos are classified by Nitto as ultra-performance street tires. Translation: they’re designed for both wet and dry traction– without sacrificing ride comfort and noise suppression. As far as testing the for G lateral force I plan to do that on the track later on for dry handling test, so far the invos are extremely quiet. For the wear factor rating, I guess I'm lucky if I can get 10K on these and as expected with ultra high performance tires, no mileage warranty is offered.
'01 E55 AMG
Joe tires look sick. I almost got these as well but went with the RE960AS I wanted a little more live out of the tires. I've been changing them every six months in the back and every year in the front. I will see how long they last on your car.
What springs did you use to lower your car? Do shops give you a hard time on aligning it and charge more money since it is lower then stock? Looks great the way it sits.
My car is almost out of the body shop, and I'm thinking of putting number 1 spring pads on it. Thanks
Oh your car is soooo clean!
E55 ///AMG
I was actually impressed how quiet these tires and it's sticky like the PS2's! I can't wait to drive it more so I can do a better review on them.
I used H&R Sport springs with Bilstein Sport shocks. I know the shop owner so basically no extra charge :)
I hope everythings okay with your car, what happened to it?
Thanks,
Joe
E55 ///AMG
Discussion Starter · #6 ·
Just an update to my review:
Note: this is conducted in W210 E55 AMG with minor modifications (H&R Sport Spring, Bilstein Sport Shocks with #2 pads in front and #1 in rear, Reso delete, X-pipe). Tires are classified as Ultra High Performance with Performace Rating of WY. Current tire set up on 245/40/18 and 275/35/18 on AMG Mono Block Aero II. 18x8 and 18x9.
First thing I noticed about the Invo was the revolutionary and asymmetrical thread design. The outside shoulder was wide while the groove on the outside was thin making the surface shoulder block really large, it's comprised of sharp angles and criss cross grooves. The inner half is made up of solid block continuous piece (continuous inner rib provides stability under braking and accelaration) with large voids.
The first minute of driving around town, I did notice a difference between the Invo and my previous tire Michelin PS2's the difference is the noise. As I said before I found the Invo's are extremely quiet, compared to the previous tires I have used in the past Goodyear Eagle F1 GS-D3 EMT; Dunlop Direzza Sport Z1 Star Spec.
Driving impression – Dry conditions
I did a high speed turn and I found the traction to be substantial with the car failing to break away (Electronic Stability Program Off), did also a high speed test on the freeways late at night and open lots, (did quick lane changes and the stability of the car felt noticeably better.) and was impressed how quiet the tires are but the grips are about the same. The comfort level was about the same as my previous tires Michelin PS2. I have not tested it for wet traction since the weather here in the bay area are always sunny.
Overall, I am happy and impressed by the Invo. I feel the Invo had better performance in dry weather compared to Goodyear Eagle F1 - GS-D3 and Dunlop Sport Z1 except for Michelin PS2.
Based on Nitto Overview:
The INVO – tread technology without compromise. This ultra-high performance tire refused to compromise on performance, ride refinement, or quality. State-of-the-art computer engineering and digital audio testing equipment produced a tread pattern that reduces perceived road noise, provide excellent comfort, and delivers exceptional traction in both and dry conditions. The result – a tread pattern that is unique and fuctional.
Tercel
I was thinking of getting bridgestone (?) on my next set of tires for the
W202 but after seeing yours over the weekend I'll probably consider these.
My W202 is lowered on Eibach with bilstein sport shocks and I've been
running Kumhos since I've dropped them (7 years now)
great review :thumbsup:
1 - 10 of 10 Posts
