1982 240d 211k miles
I've owned this car a week now and love it! My question is:
At night the gear indicator and the headlight switch are completely dark. Are these supose to be back lit? And if so, where are the bulbs at?
Thank you,
Hip
2005 Mercedes-Benz SLK350 Sport Package, 1984 Mercedes-Benz 500sel US Spec
I know my headlight switch does not light up because it is an 84. so can't help you there
When removing the center shifter console you will either have to take apart the shifter box to change the bulb (as in my 500) or you will see a wire with a white plastic piece on the side facing the ashtray that can be pulled out easily (as in a 300se I took apart)
Simon,
Thank you for your reply! I investigate this more this weekend.
