I just purchased 2003 e320 without nav unit, I would love to have one in my car. I have seen them new and slightly used on ebay. Do these item just plug and play? Is my car wired for a navigation unit s I currently do nt have a nav unit. I saw one model that plays dvds, is this true? Any advice and assistance would be greatly appreciated.
Thanks in advance,
Jeff
Not plug and play, you need at least a GPS antenna, not to mention a different wooden face plate for your dash. I do not know about the wiring, but the chances are that you need to modify/replace the wiring harness.
The newer cars have a DVD NAV unit, and I think the earliest of which is 2005. If you are going to install one, according to what I have read, the DVD unit is preferable to the CD one.
I have bought MB accessories on eBay and in general, the sellers there usually advise which units are compatible with what model(s). Before you buy anything, be sure it is something you will be able to use. If still in doubt, just give a dealer a call to ask about part numbers and/or compatibilty.
Volvo 940GLE, GMC Suburban, Infiniti I30, Toyota Prius, VW GTI, MB SLK350, Lexus IS250
Thanks in advance,
Jeff
Although the W211 Comand HU and the Nav Processor are both DVD based, they are two different boxes. The Nav Processor is located in the trunk. They are wired via the MOST opto fiber to the AGW, also located in the trunk. For all the trouble and the cost, you will be disappointed with the functionality of the Comand/Nav in the W211.
I have this setup in my '05 SLK and I use a portable Garmin Streetpilot 2620 when serious navigation is called for. MB USA sell a version of the Garmin as add on.
You can read some related discussion such as this one:
http://www.benzworld.org/forums/audio-telematics-forum/1314596-navigation-system.html
